2002 GMC C3500 Low Oil Pressure
BRIANRIGGAN27537
  • 9 POSTS
Engine Mechanical problem
2002 GMC C3500 V8 Two Wheel Drive Automatic
New distributor and oil pump. 0 psi at idle, but it rises when you give it a little gas.
Jun 17, 2008 at 10:16 AM
  • 75,988 POSTS
I recommend you check the actual oil pressure with a mechanical gauge and give us the readings-its not enough to blame the oil pressure switch-anything can go wrong here could be engine bearings/ etc-
Jun 17, 2008 at 10:43 AM
