2002 GMC C3500 Low Oil Pressure
BRIANRIGGAN27537
  • 2002 GMC C3500
Engine Mechanical problem
2002 GMC C3500 V8 Two Wheel Drive Automatic
New distributor and oil pump. 0 psi at idle, but it rises when you give it a little gas.
Tuesday, June 17th, 2008 AT 5:16 PM
I recommend you check the actual oil pressure with a mechanical gauge and give us the readings-its not enough to blame the oil pressure switch-anything can go wrong here could be engine bearings/ etc-
Tuesday, June 17th, 2008 AT 5:43 PM
