2002 GMC C3500 front rotors
32,000 MILES • V8 • 2WD • AUTOMATIC
PAUL347
truck is12 ft box with attic 4ft over cab savan cab an chassie 15000 gvw and all waighes 12000 thetruck keeps worping rotors ive changed rotors and changed pads from cermic tometelic at a lose what to due
Mar 2, 2009 at 2:05 AM
DR LOOT
  • 2,311 POSTS
you may have some bad calipers, the way to check them is;
1. Jack up the front of the van, until the tires are off the ground;
2. Turn the tires by hand, there should be no resistance, apply the brakes, spin the tires again, make sure there is no resistance.
But I think the real problem is, you have that Van very loaded, and you are waiting for the last second to slam on the brakes, try cruising a little more, in other words, when you see the light red ahead of you, take your foot off the accelerator, and try to cost, and try applying your brakes gently, 200 yards before you need to stop.
Mar 23, 2009 at 12:40 PM
