2002 GMC C3500
300,000 MILES • V8 • 2WD • AUTOMATIC
SNUFFY59
I HAVE REPLACE THE COIL AND COIL WIRE AND THE ROTOR BUG AND THE CRANK SENSOR BUT i AM STIL NOT GETTING ANY FIRE TO THE PLUGS AND I DON'T KNOW WERE TO GO FROM HERE ANY ADVICE
THANK YOU
Jun 1, 2008 at 2:05 PM
DR LOOT
  • 2,311 POSTS
you may have a bad PCM failing to send the signal to the ignition, check all of your connections including the computer under the hood, and your fuses of course.
Feb 27, 2009 at 1:58 PM
