2000 GMC C3500 Radiator Drain Valve
B.N
Engine Cooling problem
2000 GMC C3500 V8 Two Wheel Drive Automatic
Where exactly is the drain valve (petcock valve) located on this radiator?
Oct 24, 2009 at 6:59 AM
DR LOOT
  • 2,311 POSTS
the drain Valve is located on the left side, that is a driver-side, it has a 6 inch hoes connected to it, remove the hoes from its holder, point downwards into the container, open the valve, it only turns have 1/2 a turn, . So don't break it.
Oct 29, 2009 at 2:27 PM
