2000 GMC C3500 Camshaft position sensor
2000 GMC C3500
249,000 MILES • V8 • 2WD • AUTOMATIC
REDBARONII
Where is the CMP located on the 2000 350 chevy
engine? The OBD-II trouble code was P1345 =
crankshaft position /camshaft position correlation. I have
already replaced the CKP ,and that did not fis the
problem. The motor cut off and will not start. I have
visually checked the wiring , connectors etc. but
have not been able to locate the CMP . Any pointers
would help
Mar 2, 2010 at 3:54 PM
The camshaft position sensor is inside the distributor.
Mar 2, 2010 at 4:09 PM
