1998 GMC C3500 TURNSIGNAL HEADLIGHTS AND WIPERS ALL ON AT O
1998 GMC C3500
91,000 MILES • V8 • 4WD • AUTOMATIC
JEWELLDDAY
aLL LIGHTS WORK FINE WHEN RUNNING LIGHTS AND HEADLIGHTS ARE TURNED OFF. When running lights or head lights are on the winshield wipers turn on, headlights are dim one high beam and one low beam on, turnsignals lit dimmly. using turnsignals all lights dimmly flash. Just replace multi-switch and nothing changed. Any help ???
Aug 5, 2009 at 3:06 AM
DR LOOT
  • 2,311 POSTS
it sounds like you got a bad ground, make sure your battery terminals are clean, especially your ground, check your body grounds on the fender and the frame, make sure they are not corroded.
Sep 20, 2009 at 10:25 AM
