1997 GMC C3500 won't start
176,000 MILES • 6 CYL • 2WD • AUTOMATIC
PROPLUMBER
It was running fine last week . Then it would not start as if out of gas . Added gas - no help . Removed air filter and it started and ran good . Next day it would not start - removed air filter and again it started . Ran most of the day and then didnt start . Afriend was wiggling wires on air flow sensors and it started and ran good all day . Next morning wont start . Changed air flow charger sensor near air filter - still wont start . When I first try to start it it will sputter and then act as if it is getting no gas . Help .
May 5, 2009 at 3:40 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Could be several things first need to determine loss of fuel or spark. Pull plug wir ehold close to block crank spark? next spray carb cleaner into intake fire?
Let me know
Thanks for donate
May 5, 2009 at 6:41 AM
