1997 GMC C3500 my problem
1997 GMC C3500
TOMHOLL123
Brakes problem
1997 GMC C3500 V8 Four Wheel Drive Automatic
putting new rotors on a truck can not pull the old rotors off, what is holding them?
have the calipers off??
Jun 19, 2010 at 11:14 AM
MERLIN2021
  • 17,250 POSTS
Removal ("K" Series 3500 )
Remove brake caliper. (DO NOT disconnect brake hose). See FRONT BRAKE CALIPER under
REMOVAL & INSTALLATION. Remove axle shaft nut. Remove hub and bearing assembly
retaining bolts. Remove hub/bearing and rotor assembly using wheel puller.
Jun 19, 2010 at 11:22 AM
