1997 GMC C3500 bang when going into reverse gmc p3500 duall
53,000 MILES • V8 • 2WD • AUTOMATIC
ANGMAN
when driving along i hear wizzing ,then when parking some times i hear kla-klang ,i remember years ago with my 70 caddy the whizzing noise was the universal joints ,and the drive shaft had to be balanced could the rear end need oil too? please help !
Jul 17, 2010 at 7:43 AM
DR LOOT
  • 2,311 POSTS
you are correct I will first check the rear end oil if it is a very low you will probably have to replace some bearings, but the vehicle in neutral get underneath and tell me how much play the driveline has back-and-forth twisting the driveline
Sep 26, 2010 at 7:04 AM
