1993 GMC C3500 engine backfires
RACER6
Engine Performance problem
1993 GMC C3500 V8 Two Wheel Drive Automatic
truck starts and runs great at idle above 2grand it misses bad and backfires through the exhust the longer you run it the worse it gets till it won't run at all
Oct 25, 2009 at 12:31 AM
DR LOOT
  • 2,311 POSTS
you may have a pluged catalytic converter, how much exhaust is coming out of the tailpipe? can you put your hand over at and stop it fairly easy?
Oct 29, 2009 at 2:16 PM
