I'm trying to remove the auto trans in my 92 Sierra 3500, but there's a cross member sandwiched between the frame rails which contains the trans mount. I don't think I can get the trans out without removing this cross member, but I can't get it out from between the rails. Sorta looks like this: [----] I've already removed all the hardware including the trans mount hardware so it is free sliding, but there's not enough room to rotate or lift. What can I do? All my Chilton manual says is "Remove any skid plates that would interfere with transmission removal." (not helpful)
Nov 19, 2009 at 8:10 AM
