1986 GMC C3500
ROBINB
Engine Cooling problem
1986 GMC C3500 V8 Four Wheel Drive Automatic
HAS FLEX FAN WITH CLUTCH.AT FREEWAY SPEEDS FUNS HOTER THEN DRIVING SPEEDS.IS FLEX FAN OPENING UP.SHOULD I REPLACE WITH ORIGINAL I BELIEVE ITS A 6 OR 7 BLADE FAN BLADE?THANKS
Sep 13, 2008 at 5:34 PM
BLACKOP555
  • 10,386 POSTS
at those speeds a fan should have nothing to do with the vehicle overheating, it will show up as a issue at low speeds and idling.
i would check the exhaust mixture for excessive lean and bad ignition timing first.
hows the coolant level, does it stay full or does it go down on a regular basis?
Sep 14, 2008 at 9:38 AM
