2003 GMC Sierra Reduced Engine Performance Fix
KLEINHJ
i have a 2003, sierra,6.0,145000 miles,crew cab,1500 hd,4x4, my readout will pop up, reduced engine performance and my truck will not die out but will run very rough, I stop the engine, open my gas cap and recrank the engine and it will run fine,but my engine light stays on for at least a day then it goes away. this occurs at least 3or 4 times per tank of gas, and it doesn't seem to matter if is full or low or at half a tank.
Nov 15, 2007 at 11:36 AM
  • 75,988 POSTS
This is common when the throttle body needs to be serviced, here is a video to show you how also, I would also connect a scanner to see if any codesa re stored, and clear any after the service.
https://youtu.be/Z3LDHdS1upo?si=QvDS8AMFqlziB76t
Same engine so don"t worry. Please let us know what happens.
Nov 17, 2007 at 11:44 PM
Suggested Repair
Service the throttle body, then scan for stored trouble codes and clear them after the service.
Conversation Summary
A 2003 GMC Sierra 6.0 owner reports a reduced engine performance message and rough running several times per tank. Stopping, opening the gas cap, and restarting restores normal running, while the check engine light stays on for about a day. The expert says this is commonly caused by a throttle body that needs service and recommends scanning for stored codes and clearing them afterward.
