2005 GMC C2500 Low oil pressure on cluster display
60,000 MILES • V8 • 4WD • AUTOMATIC
COLMHUR
I'm working on a 2005 GMC 2500HD with a 6 liter v8. I'm getting a Low oil pressure warning on the I/C display. I have checked the oil pressure with a manual gauge, and I'm getting 5 psi at idle. I have replace the oil pump, o-ring seal on pick up tube. I'm still getting the low oil pressure. I tried a new O/P sending unit, no change. Any ideas??
May 7, 2009 at 2:28 PM
BRIAN 1
  • 1,030 POSTS
check these things,If the engine oil pressure is below specifications, inspect the engine for 1 or more of the following conditions:
• Oil pump worn or dirty
• Refer to Oil Pump Cleaning and Inspection .
• Oil pump-to-engine block bolts loose
• Refer to Oil Pump, Screen and Crankshaft Oil Deflector Installation .
• Oil pump screen loose, plugged, or damaged
• Oil pump screen O-ring seal missing or damaged
• Malfunctioning oil pump pressure relief valve
• Excessive bearing clearance
• Cracked, porous, or restricted oil galleries
• Oil gallery plugs missing or incorrectly installed
• Refer to Engine Block Plug Installation .
• Broken valve lifters
• Repair as necessary.
If the oil pressure reading on the J 21867 , or equivalent, is within specifications, inspect for the following conditions:
• Plugged or incorrect oil filter and/or malfunctioning oil bypass valve
• Malfunctioning oil pressure gage or sensor
here is the oil pressure spec,Oil Pressure - Minimum - Hot 6 psig at 1,000 engine RPM
18 psig at 2,000 engine RPM
24 psig at 4,000 engine RPM
if all this checks good you might have a problem in the guage itself in the IPC.post back with any other questions.
May 8, 2009 at 5:49 AM
