2004 GMC C2500 sensor codes
90,000 MILES • V8 • 4WD • AUTOMATIC
COREY D HELGEMO
I have a 2004 gmc sierra 2500 hd and my check engine light is on and I had hooked it to a test set and was told that all 4 of my o2 sensors were bad. Now I heard that all the sensors wont go bad at the same time and that it could be a vacum leak or a fuel pump issue. How true is that and what could it possibly be.
Apr 29, 2009 at 1:50 PM
DR LOOT
  • 2,311 POSTS
What kind of tests set? that is probably your problem, I suggest you take it somewhere and have them put a real meter (scanner) on it that will tell you which one it is, and which side its on and if it's a forward or backward one, keep in mind O2 sensors are only good for about 60,000 mile, now to answer your next question, yes a vacuum leak or a fuel pump issue will cause your O2 sensors to malfunction, but you are not describing any other problems you are experiencing with your vehicle, so have it re-diagnosed and let me know what happened.
May 21, 2009 at 4:13 AM
