2004 GMC C2500 abs light is on
43,000 MILES • V8 • 4WD • AUTOMATIC
REDZZY
replaced rear brake components rotors,calipers.pads. the system worked fine for approx. 3000 miles then abs light came on. I disconnected battery connections and reconnected with no change.
Jan 8, 2010 at 1:02 AM
DR LOOT
  • 2,311 POSTS
you may have air in the system after all that work try bleeding it again.
Due to the high volume of no responses to posted questions, if you have not resolved your issue and you need further assistance, please respond.
Jan 25, 2010 at 5:33 AM
