2004 GMC C2500 ABS light is on
REDZZY
  • 2004 GMC C2500
  • V8
  • 4WD
  • 43,000 MILES
Replaced rear brake components rotors, calipers. Pads. The system worked fine for approx. 3000 miles then abs light came on. I disconnected battery connections and reconnected with no change.
Friday, January 8th, 2010 AT 9:02 AM
DR LOOT
  • 2,311 POSTS
You may have air in the system after all that work try bleeding it again.
Due to the high volume of no responses to posted questions, if you have not resolved your issue and you need further assistance, please respond.
Monday, January 25th, 2010 AT 1:33 PM
