2003 GMC C2500 leaking fluid
70,000 MILES • V8 • 4WD • AUTOMATIC
BRICKIEMC
I replaced pads on rear,now fluid is leaking out where line connects to caliper.I bought new copper washers,still leaks, I tightened real tight, still leaks.Could the cylinder be stuck?
Aug 8, 2008 at 1:18 AM
  • 110,248 POSTS
Hi:
You could try using teflon tape to stop the leak, but I wouldn't recommend it. Are the calipers new?
Dec 15, 2008 at 10:57 AM
