2003 GMC C2500 Duramax won't start
2003 GMC C2500
50,000 MILES • V8 • 4WD • AUTOMATIC
NOMLAR
I drove my duramax less than 50 kms, parked it in my heated garage and it won't start since. It turns over fine but makes no attempt to fire up. Seems like no fuel but tank was 1/2 full & I added 5 gals. Same results. Any ideas
Feb 11, 2010 at 5:13 AM
Do below and get back asap with some testing results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
Feb 11, 2010 at 8:07 AM
Check and test the glow plugs and injection pump
Feb 17, 2010 at 5:43 AM
