2002 GMC C2500 transfer case
167,000 MILES • V8 • 4WD • AUTOMATIC
SLEDNECK
Want to know if any one knows if there is suposed to be trans. fluid draining through the transfer case? Thanks
Aug 14, 2009 at 12:37 PM
  • 110,248 POSTS
I believe the fluid in the transfer case is ATF. Is it getting overfull from the transmission? If so, the tail shaft seal may be leaking. If it is full of ATF and the level isn't raising, it is normal.
Aug 15, 2009 at 5:11 PM
