Want to know if any one knows if there is suposed to be trans. fluid draining through the transfer case? Thanks
Aug 14, 2009 at 12:37 PM
✓Experienced Mechanic
I believe the fluid in the transfer case is ATF. Is it getting overfull from the transmission? If so, the tail shaft seal may be leaking. If it is full of ATF and the level isn't raising, it is normal.
Aug 15, 2009 at 5:11 PM
