2002 GMC C2500 Hole Repair side of Transfer Case
2002 GMC C2500
90,000 MILES • V8 • 4WD • AUTOMATIC
UF90T37
Transfer case 2002 GMC 2500 HD developed a small hole on passenger side of transfer case. Dealer wants to replace transfer case for $3000. Can't afford that. Can hole be repaired by using a very short screw and applying JB Weld over the screw. What could have caused the hole?
Dec 6, 2009 at 2:31 PM
  • 31,937 POSTS
Hi there, more than likely a gear toot has failed and fractured the casing, it is not just a matter of plugging the hole, there may be further case cracking involved and you won't know what has caused this until the transfer is dismantled, i would be very concerned that the transfer will start to cause more drama if this is not checked out completely.
mark (mhpautos)
Dec 6, 2009 at 2:52 PM
