2001 GMC C2500 not starting
112,000 MILES • V8 • 4WD • AUTOMATIC
MANDYS MOM
Vehicle runs a short distance and then won't start again after shut down. Will start again after about 20 minutes. Sometimes when left idling, it shuts itself off when not warmed up. If you don't shut it off, it will run long distances with no problem.
Dec 1, 2007 at 2:36 PM
PEAR69
  • 1,482 POSTS
Is the check engine light on? Have you done any work to this truck in the past year? Specificaly the fuel pump. Are you working on this problem yourself? How long has this been going on?
Dec 2, 2007 at 1:00 AM
