2001 GMC C2500 Having trouble filling my gas tank
2001 GMC C2500
SMMAC78
2001 GMC C2500 V8 Two Wheel Drive Automatic
When I try to fill my gas tank the nosel will click off after a few second and I hear a suction noise. Any idea what might be causing this
Nov 7, 2009 at 11:34 PM
BRIAN 1
  • 1,030 POSTS
check the evap canister,see if its filled with gas.that will cause a hard fill condition as well as a restriction in the evap lines.check the filler neck fo a restriction also.
Nov 8, 2009 at 3:26 AM
