2000 GMC C2500 starting issues
147,000 MILES • V8 • 2WD • AUTOMATIC
JDRIS2206
Truck desc: 2000 GMC Sierra 2500, 147000 mi
Problem: Difficulty starting truck, takes 2-3 cranks to fire-up. Starts perfectly on a cold start, but reverts to bad starts during day. Strong fuel smell when truck is idling (burns rich). Idle is poor and truck sometimes shakes and stalls while sitting at an intersection.
Had the following replaced within last 60 days:
Plugs, wires, fuel pump
Plus, had fuel injection service
No improvement
May 3, 2008 at 1:28 AM
BUZZSAW
  • 1,198 POSTS
[quote:cd7c973e23="jdris2206"]Engine Performance problem
2000 GMC C2500 V8 Two Wheel Drive Automatic 147000 miles
No improvement[/quote:cd7c973e23]
do you have a check engine light on?
May 3, 2008 at 7:06 AM
JDRIS2206
No, the check engine light has never come on.
May 4, 2008 at 2:09 AM
BUZZSAW
  • 1,198 POSTS
[quote:827ad5ec70="jdris2206"]No, the check engine light has never come on.[/quote:827ad5ec70]
try a new map sensor, its not vary expensive and possible fuel regulator
May 5, 2008 at 9:24 AM
BLACKOP555
  • 10,386 POSTS
also would like to add possible fuel filter, vaccum leak and fuel pump relay for the idling problem at intersections. could also have play wiht the rough starting. but then again the vehicle could be running like this due to the bad MAP sensor, as buzz says, causing the vehicle to run rich.
May 7, 2008 at 2:10 PM
