2000 GMC C2500 NO REVERSE
78,000 MILES • V8 • 4WD • AUTOMATIC
HELIJOE
when reverse gear is selected, the truck will not engage. sounds like it is still in neurtral. worked fine one day and not the next.
Feb 25, 2010 at 10:01 AM
FACTORYJACK
  • 4,159 POSTS
The problem is internal to the trans, and there are several possibilities. Does it have all forward gears? Here is the list of probables for No reverse, first chart is for 4L80E trans, and second for 4L60E. This is usually a broken internal part in the trans.. common to these Chevy's
No Reverse
Checks
Cause
Case (7)
The rear band anchor pin is broken or the pin is not positioned.
Center Support (640)
Leaking at the case, or the support is broken.
Center Support Seal (639)
Leaking
Center Support Bolt (25)
• The bolt is loose or broken.
• The feed hole is blocked.
Rear Band (657)
Broken, worn, or not anchored
Rear Band Apply Pin (73)
The pin is too short or the pin is binding in the case.
Piston (65)
Binding in the case
Seal (66)
Leaking, damaged, or worn
Gasket (63)
Damaged or displaced
Cover (62)
Damaged
Bolts (61)
Broken, loose, or missing
Checkball
Missing
Fluid Pressure
Too low
Direct Clutch Components
Reaction Plates (618)
The splines are worn.
Friction Plates (611)
The splines or the friction are worn.
Spring Assembly (607)
Jammed
Housing (623)
Cracked
Piston (619)
Leaking
Seal (620, 621, 622)
Leaking
Ball Check
Leaking
No Reverse or Slips in Reverse
No Reverse or Slips in Reverse Checks
Causes
Input Housing Assembly
• 3-4 Apply ring stuck in applied position
• Forward clutch not releasing
• Turbine shaft seals missing, cut or damaged
Manual Valve Link
Disconnected
Valve Body Assembly
• 2-3 Shift valve stuck
• Manual linkage not adjusted
• Spacer plate and gaskets incorrect, mispositioned or damaged
• Lo overrun valve stuck
• Orificed cup plug restricted, missing or damaged
Reverse Input Clutch Assembly
• Clutch plate worn
• Reverse input housing and drum assembly cracked at weld
• Clutch plate retaining ring out of groove
• Return spring assembly retaining ring out of groove
• Seals cut or damaged
• Restricted apply passage
• Porosity in piston
• Belleville plate installed incorrectly
• Excessive clutch plate travel
• Oversized housing
Lo and Reverse Clutch
• Clutch plates worn
• Seals damaged
• Return spring assembly retaining ring mispositioned
Feb 25, 2010 at 2:48 PM
JASONFORD99
Mileage: 102,000. I took my truck in to my local dealership for a trans service at 85,000 miles. Up to that point, I had no problems whatsoever. Fluid nice and red but dirty. 15,000 miles after the service I noticed a low roaring noise after a 250 mile trip. I could make it stop by putting truck in neutral. I decided to check trans fluid. The fluid level was good but the fluid was as black as used motor oil. I immediately took it in to the same dealer to have it looked at. They said they had no idea what caused it. They drained fluid, replaced filter, and flushed the trans twice. Pan had NO shavings whatsoever. After driving 50 miles, the fluid still was black. Not quite as bad as previously, but still black. They told me everything checked out OK and thre had no clue as to the cause. Told me to to just drive it and watch it closely. After 500 miles it started slipping VERY badly. It barely got me back to the dealership 2 miles away. They have now told me the clutches must be worn. That's all they know. I am just wondering if there was anything that they could have done at the 85,000 mile trans service to cause the trans to fail. I have a hard time accepting it just failed, coincidentally after the service. The 102,000 miles are almost all highway miles with NO towing at all. Please give me your input.
Thank you
Mar 2, 2019 at 8:28 AM (Merged)
LOSONE
  • 1,616 POSTS
Unfortunatly it is a common story with transmission fluid changes. If a fluid looks brown it is not dirty but burned. I suspect the change and flush caused a transmission failure.
Your tranny needs to be changed every 30-45K miles.
JASONFORD99
How exactly does a change and flush cause a failure?
Prior to the trans service, the fluid looked "normal" 15K miles later (after the service) it's black.
I know it should have been changed at 50K but there is no waythat extra mileage cause it to fall apart.
LOSONE
  • 1,616 POSTS
You do no have to believe what iI say about transmissions. After 40+ years as a garage owner I can tell you some specifics about hundreds of failed transmissions.
Flushing a transmiision with discolored fluid is an "iffy "service at best. The flush chemical loosens the deposits that have been resident in all the corner, cracks and pockets of the unit.This creates a debris field that will loosen when new fluid is added and within 5K or so miles will start to create transmission woes.
The torque converter cannot be drained unless you drill a hole and put in a bolt to seal the unit. (Ford has one built in) This leaves several quarts of transmisson fluid unchanged. Flushing is often a "gimic" transmission shops use to sell an over haul. Read the fine print on the work order and it relieves them of all liability.
The act of flushing loosens deposits on all the internal working components especially the bands and valve body. These loosened deposits get in the valve body chambers and the flush fluid often distorts the small plastic balls that chamber fluid to the correct band assembly. I have seen bands come apart as they are held together in many cases by burned material.
Internally the transmission has a plethera of working parts including seals, O rings, gaskets and most important the bands. Every time a transmission shifts a minor amount of slippage occurs. This happens so the driver doesn't feel a jerk when the gears change.
Most all transmission experts will tell you that the dark deposits are from the internal parts of the transmission and torgue converter that have been loosened by an additive. oil change and most surely from a flush.
Remember your torgue converter also has a clutch that locks up giving you a 200 to 300 RPM drop and acts as an over drive. It is a very dark color and a little bit of debris goes a long way to discolor fluid.
Sadly the only way your problem can be corrected is to rebuild your transmission. I tell every one with a 2500 or larger vehicle to insure they have an aux transmisison oil color because heat is the real killer of most of the transmision problems as well as failure to service the units.
Sir; you are not alone in you transmission problems with forgetting to service a unit or expecting a magic bullet to cure everything when a high mileage unit is serviced.
Believe or don't believe what I have written, as a I am passing along facts based on my experience and beliefs. You are the end decision maker and very good luck to you.
losone
NICK SCHAEFER
I just put a brand new 480le transmission in my truck and went ten miles and it already ran up the temperature to 240 degrees. And it came with a bigger transmission cooler that I installed to. when you put it in gear it wants to die also. Never came across these problems on a brand new transmission. If you know anything please comment. Thank you
RIVERMIKERAT
  • 6,106 POSTS
Scan it for both hard and soft codes. As for the temperature, do you mean the engine temperature? It wanting to die might be a vacuum leak.
NICK SCHAEFER
It is the transmission gauge temperature, I got a scanner but how do I do hard and soft codes.
RIVERMIKERAT
  • 6,106 POSTS
It varies by scanner. Read the manual with yours. You want it to do a deep scan and find everything, not just emissions-related codes. You want it to scan for transmission codes. What you could be experiencing is excessive converter slip creating the excess heat. Also, did you blow out all the lines when you replaced the transmission?
NICK SCHAEFER
Yes sir I did blow all the lines out. I think maybe the gauge might be bad. I am going to get a heat gun and check when it gets hot.
RIVERMIKERAT
  • 6,106 POSTS
Ok. Also check to see if your scanner can give you live data and if it can, use it to check for slippage in the trans.
