The auto trans didn't want to shift,so I replaced the 1-2 shift solenoid and now some times it shifts hard
into second, it done this before the solenoid went out and stopped shifting 1-2 besides when it was cold and first started driving it.
Now it's shifting 1-2 but it does shift hard often as if it had a shift kit in it but it doesn't . What else can I do ? It has new oil and filter. Does one of these solenoid cause the problem;
pressure control solenoid, Tcc solenoid pulse width modulated, regulator solenoid, lock-up solenoid,
Second problem my truck brake lights won't light up ?
I have changed the pedal switch twices,bulbs, fuse,
what else could it be ? Is there a relay that could cause the problem or factory in line fuses before the rear tail lights that could effect it in the wiring itself ?
I need this truck operational to get me back and forth to work badley,thanks,Jim
Jan 15, 2008 at 10:43 AM
