Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
MASTERTECHTIM
CAR REPAIR CONTRIBUTOR
cam sensor problem. did you remove the distributor for any reason? this code can set if the distributor is not timed properly. you will need qaccess to a scan tool to set the timing.
