1999 GMC C2500 Odometer
17,863 MILES • V8 • 2WD • AUTOMATIC
WHEELSPINNER
I replaced the speedometer head, with a used one, as both the speed and odometer didn't work. Everything is fine when ambient temperatures are very warm or hot. When cold the odometer does not light up but might do so if the dash is given a sharp rap. My mechanic says there must be some sort of thermal switch that is the problem. What's going on?
Sep 3, 2010 at 9:39 AM
SATURNTECH9
  • 30,869 POSTS
Sound's like you just have bad odometer bulb that's what i would check.
Sep 3, 2010 at 9:55 AM
