1998 GMC C2500 grill replacement
163,000 MILES • V8 • 4WD • AUTOMATIC
WGNBRNR
i bought i new grill & need in info on how to plaece.
Mar 1, 2010 at 9:48 AM
HMAC300
  • 48,601 POSTS
you have to pull the panel off the top of it with the retainers, a screwdriver will work. there should be a few bolts holding it in on top and then clips, you'll have to look for. you'll have to squeeze the clips and pull on the grill to get it out. then reverse procedure.
May 21, 2010 at 10:57 AM
