cranks but wont start - 2500, 6.5l diesel
150,000 MILES • V8 • 2WD • AUTOMATIC
OHIO28
  • 16 POSTS
2500, 6.5L Diesel turns over, but at times wont start. Noticed the gas gauge moves a 1/4 tank past full also( to the right of full mark).
When the engine gets hot, most of the time if I shut it off, it won't start back up. Now the Dealer did some work on it and replaced the Fuel Injecting Pump. The problem still persist. What can this be? Give me your top 5.
513/10-UPDATE: Auto store scanner pulled these computer codes for turbo boost sensor and glow plugs malfunction. Hope this helps.
thanks again fellas,
Let's Go CAVS...... woo
OHIO28
May 11, 2010 at 6:04 AM
DENNYP
  • 1,824 POSTS
How long ago was the injection pump replaced?
May 14, 2010 at 11:26 AM
OHIO28
  • 16 POSTS
[quote:b640962823="dennyp"]How long ago was the injection pump replaced?[/quote:b640962823]
Denny, thanks 4 the response. I would say I had GM replace it about a month ago. Ran me close to a grand to have them do it too!
May 14, 2010 at 8:03 PM
DENNYP
  • 1,824 POSTS
It sounds like an injection pump failure to me.
It is also possible that the crank sensor is bad. You should monitor engine rpm on a scan tool while cranking the engine during a no start condition. You should see rpms above 150.
A quick check when it doesn't start.
Loosen a fuel injector line at an injector. Crank the engine and watch for fuel. If no fuel, disconnect the wiring connector on top of the injection pump. Crank the engine and see if it starts. If still no start, you have a bad injection pump(provided you have engine rpm on scan tool).
May 15, 2010 at 4:21 AM
