1997 GMC C2500 97 GMC Sierra -- No Spark
161,000 MILES • V8 • 4WD • AUTOMATIC
MIDGET777
I have a 97 Sierra, and as I was driving it died on me. I have replaced coil and ignition module, and still don't get a spark. I also checked the distributor. What else could it be?
Jun 2, 2009 at 1:44 AM
MIDGET777
I have replaced the coil, and ignition module, I got shocked when checking the distributor cap, so I figured that worked.
Jun 2, 2009 at 2:31 AM
MIDGET777
Plugs are a dark brown, they look good. I have checked for spark on the plugs, but haven't done anything else with the wires.
Jun 2, 2009 at 2:39 AM
MIDGET777
It looks like the rotor that has some corrosion. I am trying to post a picture.
https://images.2carpros.com/forum/automotive_pictures/363877_upload_1.jpg
https://images.2carpros.com/forum/automotive_pictures/363877_upload2_1.jpg
Jun 2, 2009 at 11:27 AM
Sounds like you think the issue is with the rotor and if you have replaced all this other stuff and not the rotor then I would trust your instincts.
Here is a guide that will help with checking for spark in case you need it, but it sounds like if we go with the rotor that it will solve the issue.
I am attaching the info from the manual on how to install it.
Please let us know what you find. Thanks
Jan 7, 2022 at 9:54 AM
MIDGET777
I replaced the rotor, and it was the problem. I replaced that and the cap, and it runs great.
