1995 GMC C2500 High oil pressure
14,770 MILES • V8 • 2WD • AUTOMATIC
LARRYVETTE
My truck has a serious oil leak and a mechanic replaced the rear main seal and it is now leaking worse than it was before. He now tells me that I have too high oil pressure, it idles and pretty much stays at 45psi on the guage. He tells me now that I have to replace the oil pump and the leak will stop. He also used a lot of blue sealant on the new rear main seal when he installed it. Could this have caused problems also? PLEASE HELP!!!
Jan 21, 2010 at 1:08 PM
DR LOOT
  • 2,311 POSTS
these particular trucks has a very common problem leaking oil from the oil cooler lines, also the oil pressure switch is located directly on the top rear of the engine, if leaking would make it appear as a rear main leak.
Due to the high volume of no responses to posted questions, if you have not resolved your issue and you need further assistance, please respond.
Jan 25, 2010 at 3:58 AM
