1995 GMC C2500 fuel pump
1995 GMC C2500
207,250 MILES • 6 CYL • 4WD • AUTOMATIC
CHEVY1967
I replaced my fuel pump and sensor but it still will not run, is there a fuse some where in the fuse panel??
Thank you
Sep 28, 2008 at 3:51 AM
Check no.17 ECM B 20amp fuse in underhood fuse/relay center.
Sep 28, 2008 at 4:02 AM
CHEVY1967
I changed the ecmb 20 amp fuse and had no luck.THere is no spot in my fuse panel that says fuel pump,just fuel pump sol but there is no fuse in it .There is still no fuel getting to the trottle body,I changed the fuel pump and the inline filter ,I do not here the fuel pump when I turn the key on .When I put gas down the throttle body bore it fires up right away.I also have changed the fuel pump relay.
Sep 28, 2008 at 5:09 AM
Fuel pump relay replaced-check the computer fuel pump relay control might not be energizing the relay
Sep 28, 2008 at 7:17 AM
