1995 GMC C2500 Backup lights and turn signals not working
1995 GMC C2500
252,000 MILES • V8 • 2WD • AUTOMATIC
KATIEELDER
I recently had a trailer brake installed. All the lights were working for a short time. Now I don't have reversing lights or turn signals. No turn signal indicator on the dash either. HELP!!! I have checked and replaced any blown fuses.
Aug 14, 2009 at 7:08 AM
JDL
  • 16,098 POSTS
If your talking about the turn/backup for the vehicle itself and not the trailer? Turn/back-up fuse 18 in fuse box, use a testlite, that circuit goes hot with the key on, if the circuit isn't hot, we'll have to backtrack the circuit. Maybe you need to talk to the people that wired the trailer brakes?
Aug 14, 2009 at 7:25 AM
KATIEELDER
Fuse is new 20 amp. Also, having a problem finding the relay. Is it the same relay as the hazard flashers?
Aug 14, 2009 at 7:42 AM
JDL
  • 16,098 POSTS
Even if the fuse is good, if there is no voltage on the circuit, the circuit is dead. The turn flasher shows to be located, driver side, under the dash. Sometimes these databases aren't correct about component locations?
Aug 14, 2009 at 8:26 AM
