1994 GMC C2500 oil filter housing
NOSNEH35
Engine Mechanical problem
1994 GMC C2500 V8 Two Wheel Drive Automatic
Need to know how to remove the oil filter housing from a 1994 GMC Sierra 2500 5.7L automatic. Do I need to just turn the housing counterclockwise?? - or is it more involved -- don't want to start cracking it counterclockwise if there are preliminary steps.
Thanks
Karl
aeiou1953@yahoo.com
Jul 27, 2009 at 6:01 AM
DR LOOT
  • 2,311 POSTS
I am assuming that you have a leak? after removing the oil filter counterclockwise you will see two very small bolts probably 7/16 remove those bolts and the housing will come down from the block. Any other questions you have do not hesitate to ask me.
Jul 30, 2009 at 12:57 PM
