1993 GMC C2500 Transmission repair guideline
1993 GMC C2500
200,000 MILES • V8 • 2WD • AUTOMATIC
JIMAKRIDGE
The auto trans didn't want to shift,so I replaced the 1-2 shift solenoid and now some times it shifts hard
into second, it done this before the solenoid went out and stopped shifting 1-2 besides when it was cold and first started driving it.
Now it's shifting 1-2 but it does shift hard often as if it had a shift kit in it but it doesn't . What else can I do ? It has new oil and filter. Does one of these solenoid cause the problem;
pressure control solenoid, Tcc solenoid pulse width modulated, regulator solenoid, lock-up solenoid,
Second problem my truck brake lights won't light up ?
I have changed the pedal switch twices,bulbs, fuse,
what else could it be ? Is there a relay that could cause the problem or factory in line fuses before the rear tail lights that could effect it in the wiring itself ?
I need this truck operational to get me back and forth to work badley,thanks,Jim
Jan 15, 2008 at 2:43 AM
MASTERTECHTIM
  • 4,750 POSTS
TRANSMISSIONS NOT MY SPECIALTY. ON BRAKE LIGHT ISSUE, DO YOUR TURN SIGNALS WORK IN THE REAR. YOUR BRAKE LIGHT SIGNAL GOES FROM THE BRAKE LIGHT SWITCH THROUGH THE TURN SIGNAL SWITCH THEN TO THE REAR LIGHTS. SO IF YOUR TAIL BLINKERS WORK YOU CAN ELIMINATE THE WIRING FROM THE TURN SIGNAL SWITCH BACK. *** IVE REPLACED MY BRAKE LIGHT SWITCH A BUNCH OF TIMES ON MY 94 K 1500. THE LAST ONE I BOUGHT WAS FROM GM AND I HAVE NOT HAD A PROBLEM IN A LONG TIME. I HOPE THIS HELPS.
Jan 15, 2008 at 2:58 AM
