1988 GMC C2500 died when coming to stop
150,000 MILES • V8 • 2WD • AUTOMATIC
RENEHELGESEN
Thursday, 9/24/09, I pulled up to a stop sign and it died as I pressed the brake pedal. It had not been running long, 5 minutes +/-. It would not restart. The headlights and interior lights worked, but these didn't; blinkers, sounds such as ignition or lights on, radio, power windows, idiot lights. I checked every fuse, all where good. I ended up leaving it right off the road where it died until my husband came roughly 2 hours after the initial shutdown. He is inclined with vehicles and has always done our work. After several turns of the key over a 15 min period still nothing. He couldn't figure out the problem. Then as luck would have it, he sat in the truck and said "start", it did. While it was running he jiggled some wires and fiddled with various things with no result and upon touching the brakes it died again. Then after a few tries it again started and has been fine since. He drove it about 15 miles home and it has been driven twice about 2 miles each way through our small town with plenty of stops. I very rarely have any problems with this truck it has always been dependable. I drive 18 miles to work everyday and I don't want this to happen while I'm alone at 4am on the road. He says he can't figure it out till it happens again and I refuse to drive it. Any suggestions.
Sep 28, 2009 at 1:26 AM
LUBBCRAIG
I have the exact same problems. After running for about 15 minutes, if i come to a traffic stop the car starts to stall. The lights start to dim and if i don't rev the engine the engine will die.
The first time it happened to me it turned out it was the rotor (under the distributor cap). But now it happens to me about once a year every year. So i don't know EXACTLY what it is, but that might be worth exploring.
Also, someone mentioned to me that it could be a "loose ground wire". I guess that could be a possibility, but if you have time and effort, you (or ur husband) may want to spend a few hours checking each and every ground wire for connectivity.
Oct 25, 2009 at 3:09 PM
