1986 GMC C2500 carb
JOHNNIEP
Engine Performance problem
1986 GMC C2500 V8 Four Wheel Drive Manual
i have a 350 the truck runs great if im running around town as soon as i open the 4 barrels it falls on its face gas spraying out it has new fuel pump. new pickups in fuel tanks the carb is a quadujet that was newly rebuilt
[img:f3893d32a4]http://www.2carpros.com/forum/automotive_pictures/563044_SANY1545_1.jpg[/img:f3893d32a4]
Aug 18, 2010 at 9:35 AM
WRENCHTECH
  • 20,760 POSTS
Where are you seeing gas spraying out?
Aug 18, 2010 at 9:53 AM
JOHNNIEP
out of the 4 barrel the back two ports
Aug 18, 2010 at 12:18 PM
WRENCHTECH
  • 20,760 POSTS
Then you just have a bad carburetor. Replace the carb with one already rebuilt from the factory.
Aug 18, 2010 at 12:20 PM
JOHNNIEP
this one is newly rebuilt
Aug 18, 2010 at 12:27 PM
WRENCHTECH
  • 20,760 POSTS
It was either done wrong or the housing is damaged and they didn't know it. The carb is bad.
Aug 18, 2010 at 12:29 PM
JOHNNIEP
i have also put a holly double pump on it it did the same thing
Aug 18, 2010 at 12:37 PM
WRENCHTECH
  • 20,760 POSTS
Maybe your not explaining the problem correctly but the only place fuel can come out of the carb is through the carb itself.
Now, are you getting a backfiring or something like that?
Aug 18, 2010 at 12:39 PM
