Engine Performance problem
1985 GMC C2500 6 cyl Two Wheel Drive Automatic
My van, as in most vans, doesn't have a lot of room under the hood. I have a manuel with instructions as how to check & replace the PVC valve, but it doesn't elaborate on what is above it and how to remove the things in the way to even get to it. Therefore, my question is: how do I get to the valve by removing all of the obstacles in the way or is there a way to do it w/o moving anythings else?
Thank you!
Sincerely,
S.M.
Thank you!
Sincerely,
S.M.
Jan 3, 2010 at 3:32 AM
