1985 GMC C2500 How do I get to the PVC valve to check &
SHA_NAN_IGAN
Engine Performance problem
1985 GMC C2500 6 cyl Two Wheel Drive Automatic
My van, as in most vans, doesn't have a lot of room under the hood. I have a manuel with instructions as how to check & replace the PVC valve, but it doesn't elaborate on what is above it and how to remove the things in the way to even get to it. Therefore, my question is: how do I get to the valve by removing all of the obstacles in the way or is there a way to do it w/o moving anythings else?
Thank you!
Sincerely,
S.M.
Jan 3, 2010 at 3:32 AM
HMAC300
  • 48,601 POSTS
take the engine cover off and you can reach it easily from there. it should tell you in your owners manual if you still have it.
Feb 27, 2010 at 7:30 AM
