1972 gmc 3/4 ton pickup
WRAYRAE
i have a 1972 gmc3/4 ton longhorn pickup that just drinks gas. the carb is set to specs the timing is on however it constantally pings it is a 350 eng with a 350 trans can you help it is also a 4 barrel carb and i dont drive it hard
Nov 21, 2007 at 9:14 AM
  • 75,988 POSTS
Are you overheating? Find the EGR take it out and clean it and make sure its. Inoperative EGR will cause your engine to detonate/ping.
If it has a knock sensor check that out too.
Nov 23, 2007 at 12:26 AM
