1968 GMC C2500 Timing, Dwell
1968 GMC C2500
60,555 MILES • 6 CYL • 2WD • MANUAL
NOVAMIKE
I can never find anything that deals with the rare engine my greatuncle ordered when he bought this gmc 2500 pickup truck. I am tuning it up and need timing specs., point gap, or dwell. also it has solid lifters so I also need valve adjustment specs. I truly hope you can help me because I have to smog to get registration. Thank You Michael Keyes P.S. this is a 351 c.i. V-6 !!
Mar 12, 2010 at 5:23 AM
MERLIN2021
  • 17,250 POSTS
The only engines listed are 230 250 and 292 I six, 351 engines were V8 Fords? Is this a striaght or V block engine. Where did he buy it from? V8's were 307, 327, and 396. GMC six are 170, 240 and 300. Never mind I found your V6 351! I will email the specs to you! Learn something new every day
Mar 12, 2010 at 8:48 AM
Hi Novamike, Welcome to 2carpros and TY fo rthe donation
You sure this is a V6??? 351 engines comes from a ford ( first on race day ) could be a 351M,351C and 351W they all V8's
Mar 12, 2010 at 8:49 AM
351 V6
need timing specs., point gap, or dwell. and valve adjustment
Ignition timing: 10deg BTDC
Gap: .019
Dwell/Cam angle: 31-34 deg
Tappets Hot adjustment
Intake: .012
Exhaust: .018
Mar 12, 2010 at 9:20 AM
