2000 GMC Sierra 4x4 Won't Return to 2WD
SIERRA00
2000 Sierra with 117'000 miles. The service 4x4 light is coming on. When i put it in 4 wheel drive it doesn't want to go back to 2 wheel drive . I checked the grease in the transfer case and it is good. Do you know of any issues that are common that causes this?
Nov 2, 2007 at 6:42 PM
BLACKOP555
  • 10,386 POSTS
yes do you have automatic locking hubs? sometimes they fail and you either get the wheels jammed in 4x or sometimes they wont go into 4 wheel.
to get it out try puting the vehicle in neutral with the brake on to get it into 2x if that dont work take off the brake and try to get 2x.
i would really have to go with if you have automatic hubs they are bad and should be replaced wiht manual oens.
Nov 3, 2007 at 1:31 AM
Suggested Repair
If the truck has automatic locking hubs, they may have failed and be holding it in 4WD. Try shifting to 2WD in neutral with the brake applied, then without the brake if needed. Replace failed automatic hubs with manual hubs.
Conversation Summary
The owner of a 2000 GMC Sierra with 117,000 miles reports a service 4x4 light and difficulty returning from 4WD to 2WD. Transfer case grease was checked and is good. The expert says automatic locking hubs commonly fail and can jam the wheels in 4WD, suggests shifting to 2WD in neutral with and without the brake, and recommends replacing automatic hubs with manual hubs.
