have a 92 chev k1500 - 4.3l - 5 spd. manuel - 200,000 miles - when truck has warmed up has no spark - starts fine cold - heat seems to be taking a component out of the ignition system - has a new fuel pump - fuel pump relay - starter - alt. - and coil - plugs - wires - cap and rotor - scan found code only for o2 sensor intermitent - tach is jumpy at times - any one have any ideas where i should look next - thanx
Apr 23, 2006 at 3:04 AM
