intemittant star problem
JDGRAHAMWALDORF
The truck's starter will not do anything. The radio, lights, etc. all work great. It has never happened after sitting for a long period.The poblem seems to be associated with either a hard right turn into a parking space or being warm but it has never happened or lasted long enough or me to do any testing. The way the starter is tucked in around the exhaust pipe makes it dangerous to test in a parking lot even if I could.
John
Jul 22, 2007 at 4:33 AM
DBABYN
  • 13 POSTS
[quote:5c165e82e7="edogg"]i have a 2002 f150 with 60000 miles when i tried to change the rear brakes i cannot take off the rear tires after i removed the lugs on both sides. i have aluminum wheels could they fused? i've kicked them banged on them sprayed them with liquid wrech and nothing has worked please help[/quote:5c165e82e7]\
Hello,,,it seems to me that you have run into the act of Electrolysis,,chemical reaction between steel and aluminum, just add water, static current from wheel rotation, and they will fuse over time. Add road salt in the winter and it will happen even faster. Try this,,, get a heat gun and warm up the centre of the rim,(do not over heat, if you know a welder, ask if he has a 200deg"max" grease stick that you can borrow), this where it locks up the most,,the rim will expand, and hopfully brake free. If this helps,,before putting back on, clean all part, take a half moon file(fine cross cut) and open up the centre of the aluminum rim a few thou, paint the hub or drum with a rubberized based paint, most likly will only find this in pints. Pick some NYK (corrosion preventive compond) or also known as Di-electric grease, and put a thin coating with a cloth on the back of the rim face, and in the centre of the rim. This should help to prevent this from happenning again. Let me know if this has helped.
Jul 22, 2007 at 5:31 AM
