how do I get check oil light off the instument panel off.
2001GMCS
I have a 2001 gmc serria 4.8L 4wd extended cab. I change the oil and oil fliter, now I am trying to get the light (change oil) off the instrument panel. How can I do that? Thanks alot for replying in advance!!
Nov 18, 2007 at 3:22 AM
JSHELLY186
  • 7 POSTS
At the repair shop when they do an oil change or any other services they use obd reader to clear all the service codes (i.e Change oil light, ect.). If you know anybody who has an obd I or II reader depending on year i think yours is an obd II becuase i have the same year truck that has one of these you could clear it yourself. If not alot of service shops will do it for free you just have to look around. Basically you just have to clear or reset the code from the trucks computer so it can start the mileage over again so the next time you have to change your oil it will tell you.
Nov 25, 2007 at 9:18 AM
