Thanks,
Heat/AC fan works in HI only
Thanks,
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Ask for testing of the blower-speed resistor and associated circuit before replacing more parts. Explain that high speed works and that control-module replacement made no difference.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial guidance for obtaining diagnosis or clarifying the reported findings; they are not a verified repair procedure or an independently confirmed component diagnosis.
Discussion summary
A 1995 Chevrolet C1500 4.3L had heater and air-conditioning blower operation only on high. Replacing the control module had not corrected the problem.
Reported outcome: No subsequent test or repair result was reported.
A reply suggested the resistor. The thread does not confirm its failure or provide a verified component location or dashboard-removal procedure.
