I have a 1994 Gmc 1500,96000 miles, V8 and it acts like the coil wire is off when you try to start it. It is a standard and we have been push starting it and it runs fine. What can it be?
Thanks for the help! It turned out ot be the throttle sensor. It is running great again. Thanks for telling me to put it on a code reading device.
SPONSORED LINKS
Sunday, August 26th, 2007 AT 10:48 AM
MECHANIC
Could be the ignition switch/clutch switch or starter relay.
